September 3, 201412 yr comment_3041 I have a 2002 Toyota Tacoma and the cover on the rear axle has pin hole leaks. Unfortunately the rear pumpkin cover is welded and can't be replaced so I was wondering if the tank restoration kit would seal the cover? I am not sure if it can hold up against the 80-90 gear oil. The axle housing is almost a thousand dollars to replace so was hoping that this kit might work. Any suggestions? Thanks Jim. Link to comment https://success.kbs-coatings.com/topic/1717-axle-question/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 4, 201412 yr comment_3043 Is there any way to post a picture for us to look at? I think a System Sampler Kit and some BackBone Mesh would take care of the problem flawlessly and would withstand 80-90 gear oil, but a picture would help tremendously. Thanks for contacting KBS Coatings! Link to comment https://success.kbs-coatings.com/topic/1717-axle-question/#findComment-3043 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
