June 27, 201412 yr comment_3020 This sounds like it would be great over epoxy coated wood on boats (Like the gunwales) if it will stick to epoxy. The spar varnish yellows and flakes after only 2 or 3 years and has to be sanded down and re-finished. Link to comment https://success.kbs-coatings.com/topic/1708-can-this-be-used-over-marine-epoxy/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 4, 201412 yr comment_3023 Yes, The DiamondFinish Clear works great for marine applications including epoxy coated wood. We do recommend 3 thin, covering coats to make sure you get the correct amount on the surface for your marine application. Check out the complete DiamondFinish Clear Directions HERE. Please let us know if you have additional questions. Link to comment https://success.kbs-coatings.com/topic/1708-can-this-be-used-over-marine-epoxy/#findComment-3023 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
