Klean between RustBlast and RustSeal?
Hit my freshly sandblasted metal with KBS Klean, then RustBlast.
Stupidly moved the stuff into the sun without wearing gloves (after the Rust Blast was washed off).
To make sure the RustSeal adheres well, can I use Klean again on the RustBlast-ed parts, wash it off and let dry, then paint on the RustSeal?
Thanks.
-Chris
We generally do not recommend using KBS Klean after RustBlast. But, given your situation, you can take a mild solution of KBS Klean (10 parts water and 1 part KBS Klean) and wipe off the areas where  you have finger oils, etc.
Please let us know if that helps and if you have an additional questions.
Thank you for choosing KBS Coatings!
