May 18, 201412 yr comment_3003 I did all three product steps as instructed. I notice two lip holes leaking Gold Standard while sealing. Can I add a second coat after the fist coat cures? Nothing has go into the tank after the first seal process. Do I need to worry about those pin holes? Link to comment https://success.kbs-coatings.com/topic/1700-doing-tank-seal-twice-2nd-4-days-afer-1st/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 19, 201412 yr comment_3004 The Tank Sealer does not stick to itself very well. Did you coat the outside of the tank in the areas where you saw the Tank Sealer coming through? if you want to apply another coat of Tank Sealer, make sure you buy the Fusion Self-Etch Primer along with some additional Tank Sealer. Pour the Fusion Self-Etch Primer in to the tank, rotate the tank around so all sides are coated, and then drain out the excess Fusion Self-Etch Primer. Let the Fusion Self-Etch Primer cure overnight and then do the Tank Sealer step again. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1700-doing-tank-seal-twice-2nd-4-days-afer-1st/#findComment-3004 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
