April 30, 201412 yr comment_2988 im haveing a tough time getting into some certin places to remove rust from the car if i cant remove al the rust from those spots will it keep rusting even if i get it sealed with the rust seal ? ive used a wire brush on a grinder and a handheld one aswell along with a pneumatic needle gun .but some of it i cant get to . Link to comment https://success.kbs-coatings.com/topic/1688-rust-removing/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 1, 201412 yr comment_2989 You do not have to remove every last bit of rust in order for our 3 Step System to work. Simply wire wheel whatever you can, then clean the surface with KBS Klean, etch the surface with RustBlast, and then seal it up with RustSeal. If the area will be exposed to sunlight on a regular basis, then make sure you top coat the RustSeal with a solid color uv stable top coat paint like our BlackTop. Check out the complete RustSeal Directions Here. Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1688-rust-removing/#findComment-2989 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
