New car, winter climate, most important / practical areas to cover
Hello,
My Dad is getting a new car, and it's likely to be the last car he will have. We need the car to last for a while, and in our climate (snowy winters with road salting, rainy spring and autumns) that means corrosion protection.
The car will be a Ford Focus. I assume the underside of the car and the wheel wells will have some kind of factory-applied paint or coating. We would normally take the car to a corrosion protection shop, but their treatment is not cheap and only protects for about 2 years.
Would the three-product process finishing with RustSeal work well on the underside of a new car, which presumably has some factory-applied coating already? Which areas of the car are most suitable for a DYI application of KBS' products? How much of the RustClean, RustBlast and RustSeal would roughly be needed for a Ford Focus?
Thank you!
Yes, the KBS 3 Step System will work great for you.
Are you looking to coat the frame or the frame plus the entire underside of the car?
Please let us know and we will suggest quantities for you.
