January 16, 201412 yr comment_2935 I am restoring an old truck and would like to know can you put auto paint on top of a coat of sanded rust seal? Link to comment https://success.kbs-coatings.com/topic/1658-topcoat-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 16, 201412 yr comment_2936 Yes, you sure can. There are three effective ways to top coat RustSeal effectively so that the coatings bond & fuse together. 1) Apply your top coat once the second or final coat of RustSeal is dry-to-the-touch and does not leave a fingerprint (usually 3-10 hours depending on temperature and humidity). 2) Let the second or final coat of RustSeal fully cure (at least 24 hours), scuff the RustSeal with 300 grit, then apply your top coat. 3) Let the second or final coat of RustSeal fully cure (at least 24 hours), dust the RustSeal with Fusion Self-Etching Primer, let the Fusion cure for 30 minutes, then apply your top coat. You can feel free to choose the method that will work for you. Please let us know if that answers your question and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1658-topcoat-rustseal/#findComment-2936 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
