Bekka001 Posted January 12, 2014 Report Share Posted January 12, 2014 I am currently trying to make coasters with ceramic tiles. I decoupage an image with Mod Podge to the tile and then topped it with a 2 part Epoxy, even after 3 months of curing hot coffee mugs will stick to and dent the surface. Ran across this product last night, and it sounds great. Would this product work good for a hot coffee mug to sit on it? Can I use this as a top coat over the Epoxy (Envirotex Lite). Or better yet, would this be able to replace the epoxy altogether? So could I go directly over the Mod Podge with it? Also, is it safe to use for coasters toxin wise? Also, would I be sanding the surface to prep or would I need that KBS Kleen? Thanks Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/ Share on other sites More sharing options...
KBS Coatings Posted January 13, 2014 Report Share Posted January 13, 2014 Yes, the DiamondFinish Clear should work flawlessly on your coasters. The DiamondFinish Clear will go over completely cured Epoxy and will also go over completely cured Mod Podge. The DiamondFinish Clear is completely non-toxic once cured. The only prep required would be to wipe the surface down with KBS Klean. Please let us know if that answers your questions and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-2932 Share on other sites More sharing options...
Bekka001 Posted January 13, 2014 Author Report Share Posted January 13, 2014 Oh, that is great news, I had almost given up looking for a product, so glad I ran across this. Thanks so much Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-2933 Share on other sites More sharing options...
Bekka001 Posted January 15, 2014 Author Report Share Posted January 15, 2014 Hello, have another question, Is Diamond Finish Clear Waterproof? Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-2934 Share on other sites More sharing options...
KBS Coatings Posted January 22, 2014 Report Share Posted January 22, 2014 Yes, once DiamondFinish Clear is completely cured, it is a non-porous waterproof clear coat. Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-2937 Share on other sites More sharing options...
Paul Garretson Posted October 26, 2022 Report Share Posted October 26, 2022 Question does clear diamond finish when applied to ceramic tile coasters will a hot mug stick to it after it completely dry. Will clear diamond finish when applied to ceramic coasters when completely dry will hot coffee mugs stick to the coaster. Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-5574 Share on other sites More sharing options...
KBS Coatings Posted November 7, 2022 Report Share Posted November 7, 2022 No, a hot mug will not stick to a coaster clear coated with DiamondFinish Clear once the DiamondFinish Clear has fully cured. Please reach out to us if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-5577 Share on other sites More sharing options...
Barbara A. Posted May 6 Report Share Posted May 6 I used a brush to put Diamond CLEARCOAT on a painted ceramic tile. When dried, there were brush strokes. Can the tile be put in oven to even out OR what are suggestions. Barbara A Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-9747 Share on other sites More sharing options...
KBS Coatings Posted May 7 Report Share Posted May 7 After 7 days of curing for the DiamondFinish Clear, you can lightly sand (dry or wet) with super fine grit to polish the surface, removing the brush marks. Please let us know if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1657-diamond-finish-for-top-coat-on-ceramic-tile-coasters/#findComment-9748 Share on other sites More sharing options...
