September 16, 201313 yr comment_2880 I have small pin holes just starting in bottom of pick-up truck doors and cab corners. Have been looking for a product to stop the rust so I wouldn't have to weld in new metal. What would you recommend? Link to comment https://success.kbs-coatings.com/topic/1633-pin-holes-in-bottom-of-truck-doors/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 16, 201313 yr comment_2881 This is a very common problem and we have created a How To Video just for this problem. Go HERE and watch the video entitled "Using RustSeal to Fix a Rusting Car Door". Clean the area to be coated with KBS Klean and then treat it with RustBlast. After you have completed those steps, apply 2 coats of RustSeal and then a coat of your touch up paint to match your truck. This will take care of the rusting on the outside. You can also shoot Cavity Coater up in to the cavity to keep the door from rusting from the inside. MORE INFO: The KBS 3 Step Rust Prevention System RustSeal Directions Cavity Coater Directions Please let us know if this answers your questions and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1633-pin-holes-in-bottom-of-truck-doors/#findComment-2881 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
