September 12, 201313 yr comment_2876 I forgot to rinse the rust blast off and let it dry. What can I do to correct this? I guess is that I can wet it again with rust blast and then rinse off. Howver, it is inside some of the seams and closed channels in the car body and may not rince completely. Your help will be greatly appreatiated. Link to comment https://success.kbs-coatings.com/topic/1631-rust-blast-dried-before-being-rinsed-off/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 12, 201313 yr comment_2877 Do your best to rinse it off so you do not have an excess of the Zinc Phosphate still on the surface. In the areas you can reach, you can use a green pad along with water. Please let us know if that helps and if you have additional questions. Link to comment https://success.kbs-coatings.com/topic/1631-rust-blast-dried-before-being-rinsed-off/#findComment-2877 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
