ron7k Posted June 30, 2013 Report Share Posted June 30, 2013 having the rear frame of my 2006 sierra sand blasted. what products should i use on it? also for the front of the truck under the cab is pretty bad but isn't getting blasted, what products should i use on that? the problem is the calcium chloride or whatever road salt has eaten away the metal and the oem paint and coatings on everything from the chassis to the parking brake cable brackets has flaked off. Ekbergpam and Kennethpal 2 Quote Link to comment https://success.kbs-coatings.com/topic/1612-painting-sandblasted-truck-chassis/ Share on other sites More sharing options...
KBS Coatings Posted July 11, 2013 Report Share Posted July 11, 2013 For the sand blasted areas, wipe the surface clean with KBS Klean and then apply a minimum of 2 coats of RustSeal. For the other areas, wire wheel down the surface to get rid of loose paint and rust. Then clean with KBS Klean. Etch the surface with RustBlast. Then apply a minimum of 2 coats of RustSeal. Also, be sure to check out the complete RustSeal Directions Here. Please let us know if that helps and if you have any additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1612-painting-sandblasted-truck-chassis/#findComment-2797 Share on other sites More sharing options...
