cashin Posted June 25, 2013 Report Share Posted June 25, 2013 Hi, I'm looking for a low-emissivity finish for stainless steel at high temps (research application). XTC looks like it should do the trick - do you happen to have an emissivity number for the aluminum color? (it is in fact aluminum paint, not just metallic-colored, correct?) Any tips for painting stainless would be handy as well. Thank you! Quote Link to comment https://success.kbs-coatings.com/topic/1608-aluminum-paint-emissivity/ Share on other sites More sharing options...
KBS Coatings Posted June 26, 2013 Report Share Posted June 26, 2013 The XTC has an emissivity value of .5. Yes, the XTC aluminum does have aluminum flake in it. Here are some tips for your interior application: 1) Sandblast 2) Wipe clean with KBS Klean 3) Apply 2 coats of XTC minimum and make sure you temperature cure. Other then that, just make sure you follow the directions that can be found HERE. Please let us know if that helps and if you have additional questions. Quote Link to comment https://success.kbs-coatings.com/topic/1608-aluminum-paint-emissivity/#findComment-2784 Share on other sites More sharing options...
