May 19, 201313 yr comment_2745 Hi KBS, I have read in other posts that I can apply your products to an aluminium tank that cannot be removed by using a paintbrush (after cutting an access hole). Unfortunately non of your instructions covers using this method, and I am afraid that if I overwork the product etc I may make a mess of it. Could you please provide a concise set of instructions for application using a paintbrush on an un-removable tank? I am sure that many boat owners will find this quite helpful. Thank you in advance. Instroalf Link to comment https://success.kbs-coatings.com/topic/1593-aluminum-boat-fuel-tank-not-removable-300-litres/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 20, 201313 yr comment_2746 If you are brushing the coating, it is best to use RustSeal as it lays out better when brushed or sprayed. The complete directions for RustSeal can be found HERE. Please let us know if that helps and if you have any other questions. Link to comment https://success.kbs-coatings.com/topic/1593-aluminum-boat-fuel-tank-not-removable-300-litres/#findComment-2746 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
