May 11, 201313 yr comment_2741 Hi is the tank sealer ethanol proof also is it a flexable coating or a glass like hard coat thanks steve Link to comment https://success.kbs-coatings.com/topic/1591-tank-sealer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 13, 201313 yr comment_2742 The Gold Standard Tank Sealer is not affected by Ethanol. Also, the Gold Standard Tank Sealer is flexible when cured so it can flex with your tank. You can find complete directions for the KBS 3 Step Tank Sealing System here: http://www.kbs-coatings.com/tank-sealer-directions.html You can find instructional videos for the KBS 3 Step Tank Sealing System here: http://www.kbs-coatings.com/instructional-videos.html#ts You can find Application Flow Charts for the KBS 3 Step Tank Sealing System here http://www.kbs-coatings.com/tank-sealer-flow-chart.html You can find How-To's for the KBS 3 Step Tank Sealing System here: http://www.kbs-coatings.com/how-to-use-kbs-coatings.html You can find a Fix-It Guide for the KBS 3 Step Tank Sealing System here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html (Always a great idea to familiarize yourself with it before beginning your project.) Please let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1591-tank-sealer/#findComment-2742 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
