Clear Coat My Boat
We are going to clear coat our 2001 Chapparell boat. What is the best way to apply this and will a gallon do a 26 ft x 8.6" boat? Thanks for your time. Janice Renner
You can clear coat over fiberglass with the DiamondFinish Clear. Clean the surface with KBS Klean diluted 10 parts warm water to 1 part KBS Klean. Scuff with 600-1200 grit sandpaper and and repeat cleaning process. Rinse & allow to thoroughly dry. Check out the rest of the directions here: http://www.kbs-coatings.com/diamondfinish-clearcoat-info.html Yes, 1 gallon of DiamondFinish Clear should be enough to coat your boat.
