April 23, 201313 yr comment_2716 Whats your recommendation on thinning black cote to a spray gun with a 0.5 mm nozzle! Seems like 5-10% is a little on the low side! Chris All KBS paints will need to be thinned (except Fusion) by a ratio of between 5-10%. Link to comment https://success.kbs-coatings.com/topic/1583-blacktop-thinning/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 23, 201313 yr comment_2717 We recommend a 1.5 tip and 5-10% should be plenty of thinning with the KBS #1 Thinner. You can find the complete BlackTop Directions here:Â http://www.kbs-coatings.com/blacktop-directions.html Please do not hesitate to contact us if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1583-blacktop-thinning/#findComment-2717 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 25, 201313 yr Author comment_2722 If I have to use a small detailing spray gun with a 0.5 mm tip at a recommended pressure of 50-80 psi,should I just thin it as I like with the KBS thinner? Chris Link to comment https://success.kbs-coatings.com/topic/1583-blacktop-thinning/#findComment-2722 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
