April 21, 201312 yr comment_2715 I have concrete/cement counter tops in my kitchen in Central America.What can I coat them with to prevent chipping?? (Then are choc brown with stones and shells set in so it must be clear) Thank you so much for your time and consideration. Paul Link to comment https://success.kbs-coatings.com/topic/1582-concrete-counters/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 29, 201312 yr comment_2725 You can use the DiamondFinish Clear Coat as it does dry to a very durable, clear, non-toxic finish. It would be a good idea to put some Adhesion Promoter in your first coat at a rate of 1 part Adhesion Promoter and 9 parts DiamondFinish Clear Coat. You can find the complete directions for DiamondFinish Clear here: http://www.kbs-coatings.com/diamondfinish-clearcoat-info.html Please let us know if that helps and if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1582-concrete-counters/#findComment-2725 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
