April 20, 201313 yr comment_2714 I will be starting soon on restoring a 1962 Ford F100 unibody pickup. I will be using the chassis kit (Black) on the frame and want to use it on the Engine compartment. I want to use Diamond finish clear over it in engine compartment. Can I use a Silver metal flake in the clear coat without messing it up? Thanks Nathan Link to comment https://success.kbs-coatings.com/topic/1581-metal-flake-in-diamondfinish-clear/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 2, 201313 yr comment_2727 Yes, you can use "dry" silver metal flake in the DiamondFinish Clear. It is best to get a coat down of the DiamondFinish Clear that does not have any flake in it, then another coat with the flake in it. Check out the directions for DiamondFinish Clear here: http://www.kbs-coatings.com/diamondfinish-clearcoat-info.html Please let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1581-metal-flake-in-diamondfinish-clear/#findComment-2727 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
