Clear Coat Cornhold Boards
Can the Diamond Finish Clear Coat be applied to wood? I have a set on cornhole boards that I have had to re-sand due to yellowing. so it will be applied to a painted surface.
  • 2 weeks later...
Yes, DiamondFinish Clear can be applied to wood.  This is a very common application and would work very well on your cornhole boards.  The DiamondFinish Clear will be very durable, make the boards waterproof and also will not yellow. To apply DiamondFinish Clear over your cured coating on the cornhole boards, clean the surface with KBS Klean diluted 10 parts warm water to 1 part KBS Klean. Scuff with 600-1200 grit sandpaper and repeat cleaning process. Rinse & allow to thoroughly dry thoroughly.  Once completely dry, apply 2-3 coats of DiamondFinish Clear. Re-coating can be done once the first or consecutive coat is dry-to-touch and does not leave a fingerprint.  Remember to clean your spray gun immediately after using DiamondFinish ClearCoat. Always apply coats consecutively within 6 hours of each coat curing. Average cure times are 1-2 hours, depending on humidity levels. As always, please let us know if you have any additional questions.
