March 14, 201313 yr comment_2674 Hi, I need a non-yellowing clear top coat to protect a penny floor. I want to protect the patina but epoxy clear coats will be too thick and will yellow over time. Will this coating work? The pennys are laid using a high strength moisture curing urathane glue and it is grouted. Thanks. Link to comment https://success.kbs-coatings.com/topic/1567-diamondfinish-clear-coat-over-penny-floor/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 14, 201313 yr comment_2675 The DiamondFinish Clear will work for you as it is non-yellowing and can be applied in thin, covering coats. You will want to make sure your urethane glue is completely cured before apply the DiamondFinish Clear. Check out the complete directions for DiamondFinish Clear here: http://www.kbs-coatings.com/diamondfinish-clearcoat-info.html Please let us know if you have any additional questions. Link to comment https://success.kbs-coatings.com/topic/1567-diamondfinish-clear-coat-over-penny-floor/#findComment-2675 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
