New galvanized gas tank
I want to seal the inside of a new galvanized steel gas tank. I have used a silver bearing solder on all of the external seams. Can I just  use your Aquaklean prep and then the sealer? Thanks. Ed
It would be ideal to use both the KBS Klean and the RustBlast to properly clean and etch the galvanized and silver bearing solder surface.  The surface needs tooth so the Tank Sealer adheres optimally and the KBS Klean and the RustBlast provide that tooth. Check out the complete directions for Tank Sealer here: http://www.kbs-coatings.com/tank-sealer-directions.html As always, please let us know if you have any additional questions.
