September 9, 201214 yr comment_2176 Hello, At a recent car show I came a crossed your product and fell in love with it's versatility and easy of use. Over the last week or so I have been trying to study it as much as possible. I am perparing to restore a 79 Jeep J/10 and plan to use many of your products. I would like to know are the following. 1.) Can I spray your RustBlast and RustSeal over the entire outside of the truck. I did read here on another forum page that RustBlast must be used before any NuMetal is applied to body panels. 2.) I plan to apply 3 coats of the Gloss Black RustSeal, with proper curing times adhere'd to. Once that is done I would like to apply a stripe of Oxide Red. So my question is; If I mask off an area for the stripe and take proper percautions to protect the gloss black. Will it cover effectively over another color and is any additional prep needed? 3.) How well does this product work with Fineline tape or masking tape? I do plan to apply at least 3 coats of your DiamondFinish to the entire outside of the truck once the painting is complete. Thanks in advance for any answers I might recieve, Laffior. Link to comment https://success.kbs-coatings.com/topic/1545-entire-truck/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 11, 201214 yr comment_2617 If RustSeal is going to be exposed to sunlight, we do recommend a top coat be applied that is a solid color UV stable top coat. Are you aware of this? Link to comment https://success.kbs-coatings.com/topic/1545-entire-truck/#findComment-2617 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 12, 201214 yr Author comment_2618 I was reading and believe KBS DiamondFinish Top Coat in the clear would be effective. Would you agree? Link to comment https://success.kbs-coatings.com/topic/1545-entire-truck/#findComment-2618 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 12, 201214 yr comment_2619 You can do the KBS 3 Step System over the entire Jeep, then primer, then base coat and then a clear coat (such as our DiamondFinish Clear Coat). Is that what you would like to do? We do not recommend clear coating directly over RustSeal because delamination can happen because DiamondFinish Clear is UV Stable, but like all other clear coats, it is not a UV blocker. Link to comment https://success.kbs-coatings.com/topic/1545-entire-truck/#findComment-2619 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 12, 201214 yr Author comment_2620 Humm, so this leadse to a new question. I had already planned to do the three step process. Do I have to prime over that and use another type of paint; say a PPG base and clear coat? Can I do the 3 step and just finish with a PPG clear coat? Link to comment https://success.kbs-coatings.com/topic/1545-entire-truck/#findComment-2620 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 12, 201214 yr comment_2621 We do not recommend clear coating directly over RustSeal because delamination can happen because DiamondFinish Clear is UV Stable, but like all other clear coats, it is not a UV blocker. I would recommend doing the base coat and clear coat over the RustSeal. That would be best. Link to comment https://success.kbs-coatings.com/topic/1545-entire-truck/#findComment-2621 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
