July 22, 201214 yr comment_2167 Hi, I'm trying to renovate my kitchen counters with heat resistant grill paints and wanted to give a glossy and protective surface to those counters. Could DiamondFinish Clearcoat be applied to my heat resistant painted kitchen counters - is it safe for such a purpose? Thanks very much! Link to comment https://success.kbs-coatings.com/topic/1536-faux-granite-countertops-diamond-finish-can-it-be-used/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 23, 201214 yr comment_2598 What temperature would the DiamondFinish Clear Coat need to withstand? Link to comment https://success.kbs-coatings.com/topic/1536-faux-granite-countertops-diamond-finish-can-it-be-used/#findComment-2598 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 26, 201214 yr Author comment_2599 I'm not sure about the temperature. I do put hot pans on my current Formica counters. I could certainly use trivets - probably should use trivets anyway with Formica. My concern was primarily toxicity in a kitchen environment. If the product is safe to use as a kitchen counter finish, I'd like to simulate a black/white/grey granite effect which leads me to a final question as to whether there's a possibility of yellowing. Thanks very much for your time. Link to comment https://success.kbs-coatings.com/topic/1536-faux-granite-countertops-diamond-finish-can-it-be-used/#findComment-2599 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 26, 201214 yr comment_2600 The DiamondFinish Clear is completely non-toxic once it is fully cured (roughly 7 days), it will never yellow and will withstand 500 degrees Fahrenheit. You can review the directions here: http://www.kbs-coatings.com/diamondfinish-clearcoat-info.html Link to comment https://success.kbs-coatings.com/topic/1536-faux-granite-countertops-diamond-finish-can-it-be-used/#findComment-2600 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 27, 201214 yr Author comment_2602 Thanks very much for your answers - I'll update you with photos if I do this. Thanks again! Link to comment https://success.kbs-coatings.com/topic/1536-faux-granite-countertops-diamond-finish-can-it-be-used/#findComment-2602 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
