June 6, 201214 yr comment_2155 hello, i wanted to use tank sealer on a '66 honda ca95 motorcycle gas tank. these tanks have 2 nozzles on the bottom of the tank that conncet from one to the other with rubber "fuel balance" tube. obviously the rubber tube would be removed, but do have to worry about the tank sealer clogging up the nozzles? if so, how do you recommend preventing a clog? Link to comment https://success.kbs-coatings.com/topic/1524-tank-seal-and-fuel-balance-nozzles/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 6, 201214 yr comment_2574 It would be easiest to run a pipe cleaner in those nozzles and then remove the pipe cleaner as soon as the Tank Sealer has been drained from the tank which is before the Tank Sealer sets up completely. Link to comment https://success.kbs-coatings.com/topic/1524-tank-seal-and-fuel-balance-nozzles/#findComment-2574 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
