May 15, 201213 yr comment_2150 Has DiamondFinish clear coat been tried on plastic headlights successfully? I need a sealer after sanding with 600 and 1000 grit emory. Does it contain a UV? Link to comment https://success.kbs-coatings.com/topic/1519-headlight-sealer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 16, 201213 yr comment_2556 Yes, DiamondFinish Clear Coat is used to restore plastic headlights and in headlight restoration all of the time. DiamondFinish Clear Coat is UV stable and does not yellow. You can find complete directions for DiamondFinish Clear Coat here: http://www.kbs-coatings.com/diamondfinish-clearcoat-info.html Link to comment https://success.kbs-coatings.com/topic/1519-headlight-sealer/#findComment-2556 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
