December 20, 201114 yr comment_2139 I'm cleaning and sealing the fuel tank on my Triumph TR8. I did the cleaning, then Rust Blast according to the instructions, but I started getting flash rust immediatly after rinsing after the Rust Blast. Is it OK to put the sealer over the flash rust? I thought the Rust Blast was supposed to leave a phosphate coating to inhibit rust. Link to comment https://success.kbs-coatings.com/topic/1508-flash-rust-after-rust-blast/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
December 21, 201114 yr comment_2521 As long as you have followed the directions including letting the RustBlast soak on each side for a minimum of 30 minutes in temperatures between 55 and 80 degrees Fahrenheit, rinsed the RustBlast out, allowed the tank to get bone dry and have the tank at room temperature, you can proceed with the Tank Sealing Step. It is not necessary to remove every last bit of flash oxidation before proceeding to the Tank Sealer step. You can read the complete directions here: http://www.kbs-coatings.com/tank-sealer-directions.html Link to comment https://success.kbs-coatings.com/topic/1508-flash-rust-after-rust-blast/#findComment-2521 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
