October 17, 201115 yr comment_2126 I have a 1975 Galaxy which has a built in fiberglass tank which I cannot remove from the boat. Can I paint on KBS with the same results? Link to comment https://success.kbs-coatings.com/topic/1495-non-removable-tank/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 18, 201115 yr comment_2500 Yes. If you can do all three step (AquaKlean, RustBlast and Tank Sealer) to the inside of the tank through an access hole, you can successfully seal your tank with the KBS 3 Step Tank Sealing System. =========== Gold Standard Tank Sealer DIRECTIONS ===============http://www.kbs-coatings.com/tank-sealer-directions.html =========== KBS Gold Standard Tank Sealer INSTRUCTIONAL VIDEOS ==========http://www.kbs-coatings.com/instructional-videos.html#ts =========== Tank Sealer FLOW CHART =====================http://www.kbs-coatings.com/tank-sealer-flow-chart.html =========== Tank Sealer HOW-TO SECTION =====================http://www.kbs-coatings.com/how-to-use-kbs-coatings.html Link to comment https://success.kbs-coatings.com/topic/1495-non-removable-tank/#findComment-2500 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
