October 4, 201115 yr comment_2124 I was just wondering if you can matt off the Rust Seal colors. I'm trying to reproduce a red oxide finish for a undercarriage of a vehicle that l am restoring, but l want it to be in a matt finish, or do you have a matt clear to flow coat it with? Link to comment https://success.kbs-coatings.com/topic/1493-can-i-matte-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 4, 201115 yr comment_2498 Here is a good way to matte glossy coatings like RustSeal. Apply two or more coats of RustSeal as normal. After that, apply a final coat, thinning the RustSeal at 25-35%. Apply what spray painters call a "dry coat", which is a single very thin coat with the spray gun set with lots of air and very little paint. This normally works quite well. Check out our Paint Spraying Guidelines here. Link to comment https://success.kbs-coatings.com/topic/1493-can-i-matte-rustseal/#findComment-2498 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
