September 14, 201115 yr comment_2123 What do you recommend for the following: John Deere 60"mower deck with repaired holes. Want to redo both top and underside. Deck is currently JD yellow. Needs to be resistant to normal mowing condidtions Link to comment https://success.kbs-coatings.com/topic/1492-john-deere-mower-deck-repair/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 14, 201115 yr comment_2497 I would suggest the KBS 3 Step System of AquaKlean (http://www.kbs-coatings.com/aquaklean.html), RustBlast (http://www.kbs-coatings.com/rustblast.html) and RustSeal (http://www.kbs-coatings.com/rustseal.html). After you have done the RustSeal step, you can top coat it with the appropriate colored paints to match your mower deck. You can find complete directions for RustSeal application here: http://www.kbs-coatings.com/rustseal-directions.html We also have very helpful instructional videos for the application of RustSeal that you can watch online for free here: http://www.kbs-coatings.com/instructional-videos.html In addition, we also have a Flow Chart for the application of RustSeal here: http://www.kbs-coatings.com/rustseal-flow-chart.html We also have our How-To Section which has two series of common step-by-step procedures for the application of RustSeal found here: http://www.kbs-coatings.com/how-to-use-kbs-coatings.html And before you begin your project, it is always a great idea to familiarize yourself with our RustSeal Fix-It Guides found here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html Link to comment https://success.kbs-coatings.com/topic/1492-john-deere-mower-deck-repair/#findComment-2497 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
