September 11, 201115 yr comment_2121 Hi, I have a large warehouse/office and we'd like to do the floors in Diamond Finish White. There's a few support articles on using RustSeal 20% thinned post cleaning with AquaKlean - however can Diamond Finish be applied to clean Concrete directly post prepping? Link to comment https://success.kbs-coatings.com/topic/1490-coating-concrete-using-diamond-coat/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 11, 201115 yr comment_2495 DiamondFinish White is used on Concrete all of the time. Because it is white, you will probably need 3 coats. Here are the concrete coating directions: http://www.kbs-coatings.com/concrete-sealer.html All you have to do is follow the directions but use the DiamondFinish White instead of the RustSeal. Please let us know if you have any other questions at all. Link to comment https://success.kbs-coatings.com/topic/1490-coating-concrete-using-diamond-coat/#findComment-2495 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
