August 17, 201115 yr comment_2120 Hi, After applying RustKlean and RustBlast, is it ok to wipe down with a wet rag or am I better off hosing the chassis down with water and allow it to air dry ? I'm just a bit uncertain of spraying the chassis with water considering the whole purpose is to remove the rust. Water creates rust. Also I would think the chassis would dry alot faster if it was wiped down with a wet and dry rag. cheers Link to comment https://success.kbs-coatings.com/topic/1489-removing-rustklean-and-rustblast-off-chassis/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 17, 201115 yr comment_2492 You can wipe down the chassis with a clean wet rag to rinse off the AquaKlean and then the RustBlast. Just remember to not use anything solvent based when you wipe your chassis down. Link to comment https://success.kbs-coatings.com/topic/1489-removing-rustklean-and-rustblast-off-chassis/#findComment-2492 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 17, 201115 yr Author comment_2493 Thank you for your prompt reply! Link to comment https://success.kbs-coatings.com/topic/1489-removing-rustklean-and-rustblast-off-chassis/#findComment-2493 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 17, 201115 yr comment_2494 Your welcome. Thank you for choosing KBS Coatings. Link to comment https://success.kbs-coatings.com/topic/1489-removing-rustklean-and-rustblast-off-chassis/#findComment-2494 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
