July 29, 201115 yr comment_2111 I wanted to know if you have a solution for cleaning rust off a fuel pump and sending unit, that was inside a gas tank? Link to comment https://success.kbs-coatings.com/topic/1480-clean-rust-off-of-fuel-pump-and-sending-unit/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 29, 201115 yr comment_2479 It would be best to clean it with the AquaKlean first and then soak it in RustBlast (http://www.kbs-coatings.com/rustblast.html) over night. After it has soaked, scrub it with a scotch brite pad, rinse it clear with water and dry it quickly to minimize flash oxidation. AquaKlean Directions: http://www.kbs-coatings.com/aquaklean-directions.html RustBlast Directions: http://www.kbs-coatings.com/rustblast-directions.html Link to comment https://success.kbs-coatings.com/topic/1480-clean-rust-off-of-fuel-pump-and-sending-unit/#findComment-2479 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
