chenrickson Posted June 2, 2011 Report Share Posted June 2, 2011 Just wondering if I need to use the HI-temp Primer on my sandblasted wood stove prior to applying Hi-Temp "cast iron" paint? After all the primer is only resistant up to 1200 degrees where as the paint is good to 1500 degrees. What would be the best procedure for successfully painting a stove? Thanks Quote Link to comment https://success.kbs-coatings.com/topic/1469-wood-stove/ Share on other sites More sharing options...
KBS Coatings Posted June 2, 2011 Report Share Posted June 2, 2011 If you want the best rust protection on your wood stove, please apply one coat of the Hi-Temp Primer and then at least one coat of Hi-Temp Cast Iron Grey. Hi-Temp: http://www.kbs-coatings.com/hi-temp.html Hi-Temp Primer: http://www.kbs-coatings.com/hi-temp-primer.html Hi-Temp Directions: http://www.kbs-coatings.com/hi-temp-info.html Hi-Temp Primer Directions: http://www.kbs-coatings.com/hi-temp-primer-info.html Quote Link to comment https://success.kbs-coatings.com/topic/1469-wood-stove/#findComment-2461 Share on other sites More sharing options...
chenrickson Posted June 2, 2011 Author Report Share Posted June 2, 2011 The stove will be indoors and used infrequently so I'm thinking of not priming per instructions and putting down about 3 coats of Hi Temp paint. Should I heat cure between coats or just start a fire in the stove after all 3 coats are applied? Thanks for Replying. Quote Link to comment https://success.kbs-coatings.com/topic/1469-wood-stove/#findComment-2462 Share on other sites More sharing options...
KBS Coatings Posted June 2, 2011 Report Share Posted June 2, 2011 Sounds like a plan. 3 coats of Hi-Temp would be great. Heat cure it to 350 degrees for 20 minutes for each coat. Let us know if you have any other questions. Quote Link to comment https://success.kbs-coatings.com/topic/1469-wood-stove/#findComment-2463 Share on other sites More sharing options...
