May 28, 201115 yr comment_2097 Hello, I just got my 68 Mustang back from the sand blasting (by a professional company) and it looks like they painted the whole body in a red-brown primer for corrosion resistance. I would like to paint my complete engine compartment with the Glossy Black RustSeal, and I was wondering if I had to lightly sand the existing primer with 320 grit paper or not prior to spraying the RustSeal? Of course, everything will be cleaned with degreaser afterwards. For info, I don't want to sand everything to bare metal! My other question is: do I have to thin the RustSeal if I spray with an HVLP gun with a 1.4 nozzle? Thanks for your support, great products so far! Oliver (from Belgium) Link to comment https://success.kbs-coatings.com/topic/1466-rustseal-over-existing-primer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 28, 201115 yr comment_2457 "I was wondering if I had to lightly sand the existing primer with 320 grit paper or not prior to spraying the RustSeal?" Yes. That would be great. "do I have to thin the RustSeal if I spray with an HVLP gun with a 1.4 nozzle?" Yes. Usually 5-10%. But I also have known people who do not thin it at all. But we do recommend 5-10% with KBS #1 Thinner. You can find complete directions for RustSeal application here: http://www.kbs-coatings.com/rustseal-directions.html We also have very helpful instructional videos for the application of RustSeal that you can watch online for free here: http://www.kbs-coatings.com/instructional-videos.html In addition, we also have a Flow Chart for the application of RustSeal here: http://www.kbs-coatings.com/rustseal-flow-chart.html We also have our How-To Section which has two series of common step-by-step procedures for the application of RustSeal found here: http://www.kbs-coatings.com/how-to-use-kbs-coatings.html And before you begin your project, it is always a great idea to familiarize yourself with our RustSeal Fix-It Guides found here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html Link to comment https://success.kbs-coatings.com/topic/1466-rustseal-over-existing-primer/#findComment-2457 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 28, 201115 yr Author comment_2458 Ok thank you for your support, I appreciate it! I'll try to post pictures of the result when it's done Link to comment https://success.kbs-coatings.com/topic/1466-rustseal-over-existing-primer/#findComment-2458 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 28, 201115 yr comment_2459 You welcome and we would love to see your pictures. Link to comment https://success.kbs-coatings.com/topic/1466-rustseal-over-existing-primer/#findComment-2459 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
