April 24, 201115 yr comment_2091 I see that RustStop (silver color) has a moderate UV stability. If I apply Diamond Finish over RustStop will the product be UV stable? Link to comment https://success.kbs-coatings.com/topic/1460-diamond-finsh-over-ruststop-for-uv-stability/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 24, 201115 yr comment_2447 We recommend top coatings the RustSeal with an opaque top coat if the RustSeal will be consistently exposed to sunlight. We do not recommend clear coating over the RustSeal if it will be consistently exposed to sunlight because the sunlight will still cause problems with the RustSeal and over time, we have seen the DiamondFinish actually delaminate from the RustSeal IF it has been consistently exposed to sunlight. Link to comment https://success.kbs-coatings.com/topic/1460-diamond-finsh-over-ruststop-for-uv-stability/#findComment-2447 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
