April 20, 201115 yr comment_2090 Hi, I just treated the inside of my car with aqua clean and rust blast as per the instructions to prepare for rust seal and have been left with flash off rust over the surface, should I re-treat with rust blast or is it ok to apply rust seal over this? Thanks Daryl Link to comment https://success.kbs-coatings.com/topic/1459-rust-blast-flash-rust-help/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
April 20, 201115 yr comment_2446 Surface rust is OK. If you want to minimize it in the future, you can dry the surface immediately after rinsing it with water. If you just have some light surface rust, please proceed to the RustSeal step. You can find complete directions for RustSeal application here: http://www.kbs-coatings.com/rustseal-directions.html We also have very helpful instructional videos for the application of RustSeal that you can watch online for free here: http://www.kbs-coatings.com/instructional-videos.html In addition, we also have a Flow Chart for the application of RustSeal here: http://www.kbs-coatings.com/rustseal-flow-chart.html We also have our How-To Section which has two series of common step-by-step procedures for the application of RustSeal found here: http://www.kbs-coatings.com/how-to-use-kbs-coatings.html And before you begin your project, it is always a great idea to familiarize yourself with our RustSeal Fix-It Guides found here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html Link to comment https://success.kbs-coatings.com/topic/1459-rust-blast-flash-rust-help/#findComment-2446 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
