March 14, 201115 yr comment_2086 Hi, I have some engine ancillaries, and a set of brake drums that need to have a semi-gloss (50-60%) black finish, and I wanted to know if I could use Motor Coater Gloss Black engine enamel and add a suitable acrylic-enamel gloss reducing additive (Sometimes referred to as matting paste.) to achieve the desired finish? Also, as Motor Coater is described as an acrylic-enamel, would it be compatible with normal acrylic-enamel hardeners to increase the durability? Thanks for your assistance! Steampunk Link to comment https://success.kbs-coatings.com/topic/1455-motor-coater-and-paint-additives/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 14, 201115 yr comment_2438 Yes. You can do some testing to get your acrylic-enamel reducing gloss additive to work. OR, you could mix some or the Gloss Black Motor Coater and the Jet Black Motor Coater to get your desired gloss level. You can also experiment as well with your hardeners and the Motor Coater. That should work great for you. Link to comment https://success.kbs-coatings.com/topic/1455-motor-coater-and-paint-additives/#findComment-2438 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 14, 201115 yr Author comment_2439 That's fantastic, thanks! I've got another question for you: my radiator is being rebuilt right now, and they've given me the option to either have them paint it, or paint it myself. They said they just thoroughly clean the surface, and apply a single, thin, covering coat of black aerosol engine enamel. I've got a decent touch-up gun, and I wanted to know if I could use KBS Motor Coater for this application, if applied in the method they described? I believe the finish provided by Motor Coater would be superior in both appearance and longevity to anything you could out of an aerosol can. Thank you again for your assistance! Link to comment https://success.kbs-coatings.com/topic/1455-motor-coater-and-paint-additives/#findComment-2439 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
March 15, 201115 yr comment_2440 Yes. You can use KBS Motor Coater for that application. You could also use KBS RustSeal if you so desired. Either would work great for your application. Link to comment https://success.kbs-coatings.com/topic/1455-motor-coater-and-paint-additives/#findComment-2440 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
