Walrus Posted January 28, 2011 Report Share Posted January 28, 2011 Can the various Hi-Temp paints be used over bare aluminum? Over anodized aluminum? Wish to repaint my motorcycle mufflers - scratched one, and sanded out the scratches - now need to pretty it up. Also, would I need to clearcoat afterwards to protect from UV, and is the clearcoat hi-temp resistant (the mufflers get quite hot, though certainly not 1500F!). Thanks! Quote Link to comment https://success.kbs-coatings.com/topic/1451-hi-temp-on-aluminum/ Share on other sites More sharing options...
KBS Coatings Posted January 28, 2011 Report Share Posted January 28, 2011 Yes. You can use the Hi-Temp over bare aluminum. Please make sure you use the Hi-Temp Primer to ensure great adhesion. You do not need to clear coat and if you did want to, you would need to find a clear coat that would be acceptable in your temperature range. Quote Link to comment https://success.kbs-coatings.com/topic/1451-hi-temp-on-aluminum/#findComment-2427 Share on other sites More sharing options...
Walrus Posted January 28, 2011 Author Report Share Posted January 28, 2011 Thanks! Looks like its time to order some primer and paint! Quote Link to comment https://success.kbs-coatings.com/topic/1451-hi-temp-on-aluminum/#findComment-2428 Share on other sites More sharing options...
KBS Coatings Posted January 31, 2011 Report Share Posted January 31, 2011 Please let us know if you have any other questions or if we can help you in any other way. Quote Link to comment https://success.kbs-coatings.com/topic/1451-hi-temp-on-aluminum/#findComment-2429 Share on other sites More sharing options...
