November 17, 201015 yr comment_2079 I want to apply rust sealer on my Pathfinder before winter but the temp here in the next few days will be only about 50 degrees. Is this too cold to apply? I think this is my last chance before it really gets cold. Should I forget about applying it and wait until spring? Link to comment https://success.kbs-coatings.com/topic/1448-rust-sealer-application-temperature/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 17, 201015 yr comment_2415 Ideal application temp range is 55-82ËšF. If it is colder than that, I would wait until the spring. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1448-rust-sealer-application-temperature/#findComment-2415 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
