November 11, 201016 yr comment_2078 Hi, Is it possible to weld a steel part after applying RustBlast? Same question about RustSeal? Thanks Link to comment https://success.kbs-coatings.com/topic/1447-welding-over-rustblast-or-rustseal/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 11, 201016 yr comment_2412 Yes. You can weld after the RustBlast Step. Yes. You can weld after the RustSeal is completely cured. The welding will burn away the RustSeal, so we always recommend to do your welding first and then do the KBS 3 Step System. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1447-welding-over-rustblast-or-rustseal/#findComment-2412 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
