November 9, 201016 yr comment_2077 i have a larger rust hole that formed as i began to grind on the rust probably about 5 inches long and 2 inches wide what should i do to fill it? would NU metal work for something that large? was going to try fiberglass but would it hold if i rust sealed over it? Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 9, 201016 yr comment_2409 5 inches by 2 inches is a rather large hole. You would need to weld some new steel in there. After you have done that, seal it up with the RustSeal so that it does not rust again. Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2409 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 9, 201016 yr Author comment_2410 i figured i would have to i just wondered how good this stuff really was if it could handle it.. Thanks for the info i'll try something!! Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2410 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 9, 201016 yr comment_2411 It is good stuff and will handle filling and patching holes. But your hole is just simply too large. Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2411 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 17, 201015 yr Author comment_2413 So another question! After I get the hole cover and the body filler over it and looks good do i rust seal over that or just prime it and be done with it? Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2413 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 17, 201015 yr comment_2414 I would RustSeal before the body filler so that you have your metal patch all sealed and you do not have to worry about the metal rusting under your body filler. Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2414 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 17, 201015 yr Author comment_2416 Well yeah i did that what i'm asking is do i need to over the bondo as well? Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2416 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 17, 201015 yr comment_2417 Yes. We would recommend going over the bondo with a coat or two of RustSeal. Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2417 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 18, 201015 yr Author comment_2418 okay thanks Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2418 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 18, 201015 yr comment_2419 Your welcome. Please let us know if you have any other questions. Link to comment https://success.kbs-coatings.com/topic/1446-large-rust-hole/#findComment-2419 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
