November 1, 201016 yr comment_2075 I would like to buy the cycle tank kit to restore the tank for a 1985 Honda Odyssey. My concern is that I will not be able to use the sealer because it may clog up the fuel supply lines that are inside the tank. Any thoughts or concerns? Link to comment https://success.kbs-coatings.com/topic/1444-drop-tubes-in-tank/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
November 1, 201016 yr comment_2407 You will want to keep those lines open and free using Pipe Cleaners. You can find complete instructions for the Gold Standard Gas Tank Sealer here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with Tank Sealer here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find Tank Sealer Flow Charts here: http://www.kbs-coatings.com/Flow-Chart--Tank-Sealer_ep_88-1.html Link to comment https://success.kbs-coatings.com/topic/1444-drop-tubes-in-tank/#findComment-2407 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
