October 7, 201016 yr comment_2069 I'm in the process of sealing a leaking tank. The instructions say that the tank should be left to cure for 96 hours and then says to wait 4-5 days before adding fuel. Does this mean that the 96hrs and 4-5 days are cumularive? Meaning that the tank is out of order for effectively 8-9 days (96 + 96)? Thanks Link to comment https://success.kbs-coatings.com/topic/1438-cure-time-for-tank-sealer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 7, 201016 yr comment_2391 Allow 96 hours for maximum cure and before re-filling with fuel. NOT 96+96. You can find complete instructions for the Gold Standard Gas Tank Sealer here: http://www.kbs-coatings.com/Gold-Standard-Tank-Sealer-Information-Instructions_ep_39-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with Tank Sealer here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find Tank Sealer Flow Charts here: http://www.kbs-coatings.com/Flow-Chart--Tank-Sealer_ep_88-1.html Link to comment https://success.kbs-coatings.com/topic/1438-cure-time-for-tank-sealer/#findComment-2391 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
