September 29, 201016 yr comment_2067 I am painting the exhaust pipes of my motorcycle with the Hi-Temp Primer and Hi-Temp Paint. I would really like them to have a beautiful glossy shine to them. Is the DiamondFinish ClearCoat able to withstand high temperatures just like the Hi-Temp? The product page mentions that it is "suitable for Motors and Brake calipers", but it doesn't say anything on the information sheet about what temperatures it can withstand. I look forward to your reply! Thanks! Link to comment https://success.kbs-coatings.com/topic/1436-diamondfinish-clearcoat-over-hi-temp-paint/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 3, 201016 yr comment_2389 The DiamondFinish can withstand 500 degrees F. That is much less than our Hi-Temp coating, but it is still high temperature and might be enough for your application. Link to comment https://success.kbs-coatings.com/topic/1436-diamondfinish-clearcoat-over-hi-temp-paint/#findComment-2389 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 17, 201115 yr Author comment_2425 I should probably clarify that I will not be painting the actual pipes. I will be painting the shields that cover the exhaust pipes. These shields do not get as hot as the actual pipes. I can't imagine them passing 500 degrees. I'll go ahead and order it then! If I remember, I'll write another response on here, to follow up with the results! Thanks! RTHowse Rochester, NY Link to comment https://success.kbs-coatings.com/topic/1436-diamondfinish-clearcoat-over-hi-temp-paint/#findComment-2425 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
January 18, 201115 yr comment_2426 We look forward to your response. Link to comment https://success.kbs-coatings.com/topic/1436-diamondfinish-clearcoat-over-hi-temp-paint/#findComment-2426 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
