September 13, 201016 yr comment_2064 Hi I have an area inside the top of the tank that got missed with the sealer, if I use another kit & some sealer goes over the old, will it be OK? Link to comment https://success.kbs-coatings.com/topic/1433-coating-over-tank-sealer/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 15, 201016 yr comment_2380 The Gold Standard Tank Sealer does not stick to itself very well. How do you know you missed the area? Link to comment https://success.kbs-coatings.com/topic/1433-coating-over-tank-sealer/#findComment-2380 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 15, 201016 yr Author comment_2383 I cut a square 'access panel' in the top of the tank, so I could remove the sealer that some PO had used, it was some sort of epoxy & an inch thick in the bottom corners of the tank, I cleaned & repaired the tank & used your product, then soldered the 'panel' back in place, but that joint didn't get sealed & fuel fumes found their way out & ruined the paint. I would like to seal that area before repainting. Thanks. Link to comment https://success.kbs-coatings.com/topic/1433-coating-over-tank-sealer/#findComment-2383 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 19, 201016 yr Author comment_2384 Do you think I could go through the cleaning process again & using a new kit, seal the parts that were missed? Thanks, Roy. Link to comment https://success.kbs-coatings.com/topic/1433-coating-over-tank-sealer/#findComment-2384 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
October 3, 201016 yr comment_2386 Yes. If there are holes, patch them with the NuMetal Expoxy Putty first before you do the KBS 3 Step System on the inside of the tank. Link to comment https://success.kbs-coatings.com/topic/1433-coating-over-tank-sealer/#findComment-2386 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
