September 3, 201016 yr comment_2063 Hi, I have a fibreglass motorcycle tank that I aquacleaned and then treated with tank sealer.It started to leak again and the sealer has crinkled up and can just be peeled off. I now realise that I should of rustblasted first, but would this account for the sealer crinkling up - it looks like it has reacted with the fuel? how do I clean out the sealer without damaging the fibreglass tank? thanks Mike Link to comment https://success.kbs-coatings.com/topic/1432-tank-sealer-peeling-off/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
September 15, 201016 yr comment_2377 PEELING (Flaking, Delamination)A loss of adhesion or separation of the paint film from the tank surface. CAUSE:Improper preparation of the substrate (cleaning & etching).Inadequate drying of tank interior prior to applying sealer.Too hot/humid atmospheric and/or tank surface conditions during application or curing. REPAIR:Strip out Tank Sealer (Using KBS Strip). Repeat AquaKlean, RustBlast, and Gold Standard Tank Sealer steps. PREVENTION:Thoroughly clean and prepare all tank surfaces according to product recommendations.Allow tank interior to dry completely before applying sealer.Allow tank to reach normal room temperature before applying sealer.Allow tank to dry slowly at room temperature.Do not attempt to "speed up" the cure time by placing tank in direct sun or near heat source. Yes, the sealer will crinkle if it never has a chance to fully cure because the surface was not etched with the RustBlast. You can find complete instructions for the Gold Standard Gas Tank Sealer HERE. You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with Tank Sealer here: http://www.kbs-coatings.com/fix-it-guide-tank-sealer.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find Tank Sealer Flow Charts here: http://www.kbs-coatings.com/Flow-Chart--Tank-Sealer_ep_88-1.html Link to comment https://success.kbs-coatings.com/topic/1432-tank-sealer-peeling-off/#findComment-2377 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 17Aug 17 comment_10526 Updated for 2026: The process in this thread is still correct, with current product names and links.The cleaner formerly called AquaKlean is now KBS Klean.To repair a peeling tank liner: strip out the old sealer with KBS Strip, then repeat the full 3-step process with KBS Klean, RustBlast, and Gold Standard Tank Sealer.Tank Sealer directions: https://kbs-coatings.com/tank-sealer-directionsFix-It Guide: https://kbs-coatings.com/fix-it-guide-tank-sealerTank Sealer Kits: https://kbs-coatings.com/tank-sealers Link to comment https://success.kbs-coatings.com/topic/1432-tank-sealer-peeling-off/#findComment-10526 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
