August 6, 201016 yr comment_2057 How should I prep hard ano for the rustseal? Just sand with 320 then use the standard prep? Link to comment https://success.kbs-coatings.com/topic/1426-hard-anodized-aluminum/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
August 6, 201016 yr comment_2372 Yes. That would be great. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1426-hard-anodized-aluminum/#findComment-2372 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
