July 8, 201016 yr comment_2056 is it possible to paint rust seal over fiberglass? also will rust seal work over old paint/primer or only on raw metal thanks Link to comment https://success.kbs-coatings.com/topic/1425-rust-seal-on-fibreglass/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 9, 201016 yr comment_2365 Yes. You can paint RustSeal over fiberglass. RustSeal usually will stick to other coatings if they have been cleaned and scuffed. Link to comment https://success.kbs-coatings.com/topic/1425-rust-seal-on-fibreglass/#findComment-2365 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 9, 201016 yr Author comment_2366 cheers, another question, if painting with satin black rust seal do i need a top coat as the paint is likely to be exposed to sunlight? im worried about color change Link to comment https://success.kbs-coatings.com/topic/1425-rust-seal-on-fibreglass/#findComment-2366 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
July 12, 201016 yr comment_2367 Yes. You will want to top coat if the RustSeal will be consistently exposed to UV Rays. Link to comment https://success.kbs-coatings.com/topic/1425-rust-seal-on-fibreglass/#findComment-2367 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
