June 3, 201016 yr comment_2053 Can I use rustseal on a stone or concrete surface by first using a thinned down rustseal and then a second coat of rust seal. I need a really good paint like rustseal to go on as a primer before I gold leaf a stone pinnacle on a building. The gold leaf needs a sound base to adhere to Link to comment https://success.kbs-coatings.com/topic/1422-can-i-use-rustseal-on-stone-masonary/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
June 3, 201016 yr comment_2360 What color do you need. If you need Clear, you might want to consider using DiamondFinish Clear because it is UV Stable. You can find DiamondFinish here: http://www.kbs-coatings.com/diamondfinish-clearcoat.html Link to comment https://success.kbs-coatings.com/topic/1422-can-i-use-rustseal-on-stone-masonary/#findComment-2360 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
