May 26, 201016 yr comment_2052 Hi. Can RustSeal be used on the inside of an engine oil pan? I have a custom fabricated oil pan that Weeps oil through porosity in the weldments. I would like to coat both the inside and outside of the pan to seal it. I can strip the pan down to bare metal before I start. Thanks. Link to comment https://success.kbs-coatings.com/topic/1421-rustseal-on-inside-of-oil-pan/ Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
May 26, 201016 yr comment_2358 Yes. RustSeal can be used on the inside of the oil pan. Get the pan VERY CLEAN using the AquaKlean, etch it with the RustBlast and then apply 2-3 coats of RustSeal. If you have any holes, patch them with KBS NuMetal Epoxy Putty after you clean the oil pan. You can find complete instructions for RustSeal here: http://www.kbs-coatings.com/RustSeal-Information-and-Instructions_ep_38-1.html You can also find the Fix-It Guide which will help you quickly identify the causes of and the recommended solutions for the most common issues that could occur with RustSeal here: http://www.kbs-coatings.com/fix-it-guide-rustseal.html You can also find Instructional Videos here: http://www.kbs-coatings.com/KBS-Videos_ep_90-1.html You can also find a Flow Chart for using the KBS 3 Step System here: http://www.kbs-coatings.com/Flow-Chart--RustSeal-on-Steel_ep_87-1.html Link to comment https://success.kbs-coatings.com/topic/1421-rustseal-on-inside-of-oil-pan/#findComment-2358 Share on other sites Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Report Share this post
